Home Forums Products Stompboxes Phase issue with H9 and Suhr Mini Mix II that does not occur on my Eclipse Reply To: Phase issue with H9 and Suhr Mini Mix II that does not occur on my Eclipse
#125908
The replacement H9 sounds very nice but now the midi doesn't seem to be working  — H9 set to OMNI on Midi receive channel and I left the Program Change map as it was …
In other words, if the H9 is set to receive the midi data via the "In" midi port from a verified device, such as my RJM foot controller or my Nobles MS-4 (midi channel selector for my guitar amp), the H9 does not respond to the midi command changes initiated by my foot controller whereas the Eclipse and the MS-4 do …
Ideas on this new question?
btw: is there a way to create a midi command to mute the effects and display the tuner?
Thanks in advance ….
