Home › Forums › Products › Stompboxes › Phase issue with H9 and Suhr Mini Mix II that does not occur on my Eclipse › Reply To: Phase issue with H9 and Suhr Mini Mix II that does not occur on my Eclipse
May 11, 2014 at 10:20 pm
#125909
In followup, I have discovered that in order for the midi changes to be received by the H9 the USB cable (used with a computer) must be removed from the H9 — I am not sure if this is documented but it sure would have saved a lot of troubleshooting time if it is; further, I am not so sure how advantageous this limitation is — maybe a software fix is possible, etc.?
thank you again!
