Home › Forums › Products › Stompboxes › Time factor powers on and off › Reply To: Time factor powers on and off
May 14, 2014 at 3:22 pm
#125935
It does sound as if you have some sort of power supply problem. You probably still have the factory power supply from the TF – you could perhaps try rotating the three supplies around the two pedals and see if there is one supply that works on either pedal.
Otherwise you will probably have to contact support@eventide.com and have the units checked.
