Home Forums Products Plug-Ins ultrachannel fails validation in logic 8 Reply To: ultrachannel fails validation in logic 8
#126159
tamprecision
    hey dan i looked at the license manager and it was active on the ilok key, I have an ilok key
    i tried transferring it to the computer but got the same result
    im running on mac osx 10.5.8 – could this be the problem
    thanks SO MUCH for your help Dan, really really appreciate it
    heres the message i got when the license was active on the computer
             AU Validation Tool
             Version: 1.2.1b3
              Copyright 2003-2007, Apple, Inc. All Rights Reserved.
             Specify -h (-help) for command options
    VALIDATING AUDIO UNIT: 'aufx' – 'UlCh' – 'Tide'
    Manufacturer String: Eventide
    AudioUnit name: UltraChannel
    Component Info: Ultra Channel
    Component Version: 2.0.5 (0x20005)
    Component's Bundle Version: 2.0.5
    * * PASS
    TESTING OPEN TIMES:
    COLD:
    2014-06-18 02:39:10.373 auvaltool[196:80f] Error loading /Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel:  dlopen(/Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel, 262): no suitable image found.  Did find:
    /Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel: unknown required load command 0x80000022
    FATAL ERROR: OpenAComponent: result: -50,0xFFFFFFCE
    validation result: couldn't be opened
    updating properties of AU UltraChannel by Eventide…FAILED!
