Home › Forums › Products › Stompboxes › Does the Time Factor quantize loop length to external MIDI clock? › Reply To: Does the Time Factor quantize loop length to external MIDI clock?
June 21, 2014 at 3:50 pm
#126177
The current one does not. But we're working on it for the next version – this is one reason why it is delayed.
Less anyone misunderstand this, the tracking will not handle tempo changes – for example it will not time-compress the loop if you speed up the tempo – it will instead cut a bit off the end.
