Home › Forums › Products › Stompboxes › Latency in factor pedals set with the DSP-bypass option? › Reply To: Latency in factor pedals set with the DSP-bypass option?
September 10, 2014 at 8:37 am
#126663
Yepp your explanation is correct, but still, with relay mode i dont have that problem, or is it just less obvious? With less obvious i mean maybe the problem is there but only when effects are on. I play metal so i have a hard time hearing subtleties when we play the whole band. 🙂
Could Kill dry be a solution to phase issues really? (then i could live with just using one loop-pedal at the time)
Anyhow, im pretty fed up with this loop by now… Im going to look into the cost of transforming it to a serial loop as well.
And thanks guys for the feed back so far! 🙂
