Reply To: Space Aux Switch
Home Forums Products Stompboxes Space Aux Switch Reply To: Space Aux Switch
#126666
gkellum
tom baxter:
i am completely perplexed at how complicated this whole AUX pedal set up is?
It should be really easy to set-up. There was a bug in the v5.0.0[0] release of Space which caused Aux switches not to work on newer Spaces.  Maybe, you have that release installed on a newer Space and that's why you're running into so many problems?  If you go into Space's system settings, it will tell you under Utilities which version you have installed. Also, H9 Control will tell you which version you have installed when you go into Pedal settings. If that is in fact the problem, you should upgrade to the latest release 5.0.0[4] which you can download through our updating software, which should fix the issue.
