Reply To: Question on Rationale behind MIDI Transmit Map & Foot switch.
Home Forums Products Stompboxes Question on Rationale behind MIDI Transmit Map & Foot switch. Reply To: Question on Rationale behind MIDI Transmit Map & Foot switch.
#126910
artistvip
I think you can do what you want with the current features. The MIDI "Thru" option on the Factor pedals simply passes the messages from your MIDI controller through to the next MIDI device connected. So why not set the RCV MAP of each Eventide pedal to call up the Preset that you want when it receives a program change of 1-9 from your controller?
