Home › Forums › Products › Stompboxes › Possible bug in the H9 Looper › Reply To: Possible bug in the H9 Looper
November 27, 2014 at 7:53 am
#127066
ok, thanks for clarifying!
When in DUB mode it always displays 1X before STOP. In play mode this doesn't happen. In DUB mode you have to wait for the STOP sign to be able to press again twice to empty the loop. This is making emptying the loop slower I think. Or at least you can not tap the Fw for the 1X disappears (?).
About the P:LOOP. I didn't know it only stopped after the max loop time. I thought it also should stop when you stop recording with the left Fw. My mistake. Can you give some practical use for using the LOOP over AUTOPLAY?
