Home Forums Products Stompboxes H9 tap tempo problems Reply To: H9 tap tempo problems
#127215
gkellum
    Since you're new to the H9, it would be good to eliminate any chance of there being confusion about how this feature works. After you turn on tap tempo, you're long pressing on the right footswitch  so that you can use that footswitch to tap in the tempo, correct? After doing so you see the LED about the right footswitch start to blink in time with the current tempo, but when you start tapping on the right footswitch, it doesn't cause the tempo to update to your newly tapped in tempo?
