Home › Forums › Products › Stompboxes › H9 incoming tap tempo issue › Reply To: H9 incoming tap tempo issue
February 24, 2015 at 6:46 pm
#127580
jaime136:
This goes to an Avid Eleven rack set on MIDI channel 1. The CC# is 64 as this is what the Eleven requires and this works fine.
Because you already got it working between the G-system and the Eleven rack there's also another option. Which is not the best way to do it but should also work.
2nd Option:
Plug a midi cable from midi OUT of the Eleven Rack to the midi IN of the H9
– The Eleven Rack should be set to transmit midi clock
– The H9 should be set the same way as I wrote before
LA
