Home Forums Products Stompboxes Input level +4dBu or -10dBV for Eventide Space Reply To: Input level +4dBu or -10dBV for Eventide Space
#127788
    Probably either, as long as you set the Line switch on the Space appropriately. Can't give a definite answer as these level numbers are usually nominal, and it is hard to know what the actual levels are. -10dBu is probably safer.
