Home › Forums › Products › Stompboxes › Edge ‘Streets’ sound from amnesta.net › Reply To: Edge ‘Streets’ sound from amnesta.net
February 25, 2008 at 8:42 pm
#128054
For "Streets" all you need is one delay set at about 365 ms with a wet/dry ratio of 50/50. Add a little bit of modulation, and off you go. Simple as that. Use the Time Factor's vintage delay, and if you've got it nailed, imo.
If you're interested in learning a lot more about Edge's sounds, join our yahoo group, U2 Recording.
Jeff
