Home Forums Products Stompboxes Modfactor occasionally stops ” undulating ” ? Reply To: Modfactor occasionally stops ” undulating ” ?
#128302
it seems there are some other folks in this thread reporting the same.
We would like you to do a simple test:
-load the factory Undulator preset and play. DO NOT CHANGE ANY PARAMETER! Don't touch any knob.
-if it's working fine, procedd to ONLY change the lfo shape to SINE. Don't tuch any other knob. Does it work?
-Please describe how the MF is connected to your gear with the following details:
-type of cables
-connection to guitar or fx loop?
-if it's inside an FX loop, what's the signal impedance (+4dB/-10dB)?
Thanks
best
