Home › Forums › Products › Stompboxes › Analog BBD, Tape echo, and Vintage Digital Rack ideas › Reply To: Analog BBD, Tape echo, and Vintage Digital Rack ideas
April 11, 2008 at 1:39 pm
#128470
The real trick with the SDD3K is to make sure that there is good grounding connections between the various jacks, and also on the circuit boards themselves. Over time the grounding screws can come loose on the boards, and this can lead to increased noise, and eventually very chaotic behaviour of the delay. The Timefactor is less noisy than my SDD3K, except when I'm usng the vintage delay algorithm.
Are you using Beta 2.xxxx on the TF, or ver 1.1. I think that 1.1 sounded better….noisier, but no gating etc.
Cheers
Kris
