Home Forums Products Stompboxes Which momentary aux switch is best Reply To: Which momentary aux switch is best
#128479
cattaneo
     I use the Boss fs-5u as an aux switch for tap tempo and recommend it. Remember that a metal switch is not particularly suddle when performing on stage or recording in the same room as your gear. Depending on the kind of music you're playing/recording, keep in mind that frantic tapping on a metal switche is pretty noisy, while the Boss option is totally quiet. For tap-tempo, it works fine.
