Home Forums Products Stompboxes Noisy Vintage Delay Reply To: Noisy Vintage Delay
#128560
 If it's noisy with no signal present, I assume you're on rev
1.1 of the firmware…I seem to recall it getting quiet with no input
signal with the Beta rev 2.0 version of the software. But, I recall,
getting a 'gating' kind of sound…which I figure is due to a lack of
dither. I figure that Version 1.1 had dither on the signal, which
explains the noise (dither is noise…shaped noise, but noise
nonetheless), but they took it away, or changed the way in which it was
implemented in version 2.0. I'll need to double check this though, as
it's been a while since I've used my TimeFactor (I'm 3/4 of the way
through a pedalboard construction project so most of my pedals are
currently out of service).
I can check it out tomorrow though since I aim to finish my board off tonight…
Cheers
Kris
