Home Forums Products Stompboxes Communication between PF, TF and MF Reply To: Communication between PF, TF and MF
#130039
Hi everybody! I'm interested in buying TF+PF. But I would like to know if it's possible to:
1- Connecting thrue midi, TF in bank mode e PF in play mode -> Using TF to change bank and program in each pedal and at the same time, using the tap-tempo of PF to set the clock to each pedal, is it possible? Or I need an aux pedal for example to PF and set it "Master"?
2- And if I have also an E.B. jp25k volume pedal conected to PF. With the same set up described in the first question (TF for change program/bank + PF for change tap-tempo), can I also manage different parameter simultaneously of the 2 pedal?
Sorry for my language, I hope you understandSmile
Andrea
