Home Forums Products Stompboxes Can I use TimeFactor in my Series Effect Loop? Reply To: Can I use TimeFactor in my Series Effect Loop?
#130817
I'm not sure I understand what your problem is. Are you saying that only the repetitions are distorted? The mix control shouldn't make any difference as it is only a balance control and should not alter the sound of the repetitions. If it does, the distortion has to happen after the Timefactor, but this distortion will also happen to the direct signal.
You're using a regular insert cable (TRS jack to two TS jacks) with the Ceriatone, and the TF is set to "line" for both input and output?
