Home Forums Products Stompboxes Can I use TimeFactor in my Series Effect Loop? Reply To: Can I use TimeFactor in my Series Effect Loop?
#130819
alwalt
    Last night I tested the TF with an solid satate amp. I worked flawsely in front of the amp. Then I tried it in front of the DC30 on a lower gain setting, and it also worked a lot better. These are good and bad news, as I realized that higher amounts of gain on the amp will cause the TF to "collapse" the sound, but I would really like to be able to crank the amp and use the TF.
    Otherwise, I will be forced to use lower gain settings and overdrive with pedals. I guess some tweaking is ahead the road. My bad, I was blaming the TF, but it seems the interaction of the amp voltages (I recently installed VVR) has something to do with the incoming and outcoming signal of the TF. I still want to update from the beta version, thou…
