Home › Forums › Products › Stompboxes › One expression pedal for two units? (on A/B switch) › Reply To: One expression pedal for two units? (on A/B switch)
January 19, 2010 at 9:32 pm
#130973
Hey Russ,
So–as far as the Factors are concerned–I could use my thru box and still set things up the exact same way you described above? I wouldn't have to change a thing as far as the programming was concerned? The only difference (obviously) would be my physical MIDI cable connections.
Thank you,
Jeff
