Home Forums Products Stompboxes Any way to prevent outgoing CC transmit to through port Reply To: Any way to prevent outgoing CC transmit to through port
#131127
Ok,
Brunetti is telling me that modified chips will cost $150 + S&H + Local tech install fees (about $300 total + 3 – 4 weeks delivery + 3-4 weeks possible installation) YIKES!  I can't afford the $$ or the time right now so I need a workaround.
Once again,
Is there any way to filter out CC messages on the through port while allowing PC messages to pass?
If not:
What kind of cables will I need to use a non MIDI expression pedal with the TimeFactor (stereo or mono)?
Also, is it possible to use the aux port on the TimeFactor with a second expression pedal or only the expression pedal port?  I have dual expression pedals on the FCB1010 and I'd like to use both of them.
