Home Forums Products Stompboxes One expression pedal for two units? (on A/B switch) Reply To: One expression pedal for two units? (on A/B switch)
#131138
wedelich
    Dan,
    If the G-minor has an expression pedal input that can be transmitted over CC, then yes, you can assign it to a MIDI CC and control it from there.  Otherwise, the MF is either a MIDI thru box or a transmitter.  As either, it can receive MIDI commands and respond, but the MIDI transmit functionality either generates new and isolated MIDI commands or passes commands from input, but not both.
    To me though, the G-minor sounds like a redundant piece of gear.  The MF will do everything it does (send program change and MIDI CC) plus expression pedal control.  Is there something in particular you need the G-minor for that you don't think a factor pedal will do?
