Reply To: One expression pedal for two units? (on A/B switch)
Home Forums Products Stompboxes One expression pedal for two units? (on A/B switch) Reply To: One expression pedal for two units? (on A/B switch)
#131140
TheDan
I have it laying around from my G-Major days and thought I give it a shot. I use it to go up/down the banks, bypass both units and to control the brake/repeat function. Easy to programm. I didn't go into the MF midi functions as a master pedal but I will work through it. The only thing the MF can't is going down the banks. So I think I will continue without the GM. The expression pedal function with midi is way too cool.
Thanks Russ, maybe you have a few guidelines how to programm it, since you use one to control all three.
I'm going to change my chain. First TF than MF.
