Reply To: Any way to prevent outgoing CC transmit to through port
Home Forums Products Stompboxes Any way to prevent outgoing CC transmit to through port Reply To: Any way to prevent outgoing CC transmit to through port
#131148
MaxFX:
Is it possible to:
A. Set the Eventide OUT port to XMT instead of THRU (which will block all signals going out to the Brunetti)
Yes
MaxFX:
B. Set the XMT CC to OFF
Yes
MaxFX:
C. Set the PGM XMT to ON and Have the Eventide transmit PGM changes from the Behringer to the Brunetti?…
Probably not – this would require THRU mode, which will lose the PGM XMT out. You'll need a MIDI Merge box to do this.
