Reply To: External Control of “Bypass Mode” in Time Factor Pedal…
Home Forums Products Stompboxes External Control of “Bypass Mode” in Time Factor Pedal… Reply To: External Control of “Bypass Mode” in Time Factor Pedal…
#131733
I assume you are using TF. This has a feature called SPILLOVER, which if set, will preserve the delay "tails" from the previous preset. Note that these tails are now going part of a different effect, so may change in sound.
