Home Forums Products Stompboxes Selecting TOG/BYP/ACT problem MidiMapping Reply To: Selecting TOG/BYP/ACT problem MidiMapping
#132006
achaput
    The other way to select Bypass using MIDI is with MIDI Continuous Controller.
    From PitchFactor's MIDI/RCV CTL menu you can select which MIDI CC will operate BYPASS.
    After you choose a MIDI CC number for this, you should be able to set a button on the MIDImate to transmit that same MIDI CC and bypass the PitchFactor that way.
    -Alan
