Reply To: Time Factor – expression pedal not holding the setting?
Home Forums Products Stompboxes Time Factor – expression pedal not holding the setting? Reply To: Time Factor – expression pedal not holding the setting?
#132177
ctc
My Timefactor is new (I think I bought it in July 2010), it has never been used on the floor with my feet (only on top of my amp with my hands), it is always covered when not in use, it has never been outside, and I blew clean compressed air through the jacks as you recommended to no avail. The numbers keep jumping all over the place when connected to the auxiliary switches and/or expression pedal! Additionally when using the looper, the display will frequently appear like it does in bank mode, and after I step on an aux pedal, the display will briefly change to a play mode parameter before properly acting like the looper. Sometimes it takes a while for it to start acting this way, but once it does it continues for the rest of the session. Please advise.
