Home › Forums › Products › Stompboxes › Update problem…yes another one › Reply To: Update problem…yes another one
December 10, 2010 at 12:05 am
#132322
Sorry, I meant MIDI CLK OUT set to OFF. Must've been in a hurry when I typed that… I had MIDI OUTPUT set to THRU, but I think it's the clock out setting that's causing the issue. I also had CLK IN set to OFF. Changing the clock out setting is what fixed my problem. I'm not sure if this is what's causing your issue, Tazwolf, but I hope you get it working!
