Home › Forums › Products › Stompboxes › Crossfade feature in Timefactor › Reply To: Crossfade feature in Timefactor
January 27, 2011 at 1:23 am
#132668
I believe, although I could be wrong, that crossfades happen whenever the time between repeats change. That includes almost all multi-tap delays, whenever any delay is modulated, anytime you change presets, anytime you change the delay time or the delay type, or anytime an expression pedal, aux switch, or MIDI CC changes the delay time or modulation settings.
