Home › Forums › Products › Rackmount › Eventide H8000 : Trying to remote the levels and something wrong happens in the preset parametres › Reply To: Eventide H8000 : Trying to remote the levels and something wrong happens in the preset parametres
February 23, 2011 at 11:36 pm
#132830
E.M Pulinx:
The first key does come underlined eq and low dB -10dB also underlined in white.If you press reverse,then reverse becomes underlined as the reverse t_lenght 13/16 , the same for the 2 others soft keys
The soft keys will always appear to be underlined. Are any of the parameters that change underlined ?
E.M Pulinx:
1 292
This is the boot software version. The second screen will give you the main version. This should be V5.5. If not, please upgrade.
