Reply To: Wet dry outputs on the Time Factor (or any other Eventide stompbox)
Home Forums Products Stompboxes Wet dry outputs on the Time Factor (or any other Eventide stompbox) Reply To: Wet dry outputs on the Time Factor (or any other Eventide stompbox)
#132901
merkaba22:
I'd want to know what to tell a tech
You need someone you can work with and tell them precisely what you need. I'm not really sure what you are trying to do, and either way, it would likely go beyond the scope of this Forum. You might also want to talk to the amp manufacturer.
