Home Forums Products Stompboxes Wet dry outputs on the Time Factor (or any other Eventide stompbox) Reply To: Wet dry outputs on the Time Factor (or any other Eventide stompbox)
#132909
Technically, you never exactly said that you were trying to "create a parallel loop"… Whether or not it's sonically necessary is up to your ears.
It might be useful to understand why digital processing necessarily involves "phase issues," regardless of who made the digital device. It also might help to not assume that everyone here uses some kind of cheap distortion pedal…
I think the best thing you can do is to try your setup both with Y-Cables and with a Suhr Mini-Mix. You might want to try it with the series loop, too. Trying it yourself is the only way you'll know what sounds best to you, you know?
