Home Forums Products Stompboxes Midi control of MF from TF Reply To: Midi control of MF from TF
#133206
So, unfortunately, I think we are back to  my original issue: you can't (w/o midi merge/ thru…) send both clock and (external) PC info from one to the other.  If I select Midi out to XMT Midi clock, I lose ability to send midi thru w/ PCs from controller.  If I select Midi Thru to get PC from controller, I lose midi clock from TF, right?  I've heard the midi merge/ thru solution and understand it.  But, that's what I was trying to avoid.  Sending clock via CC is not practical in my case.
So, I guess the answer to my OP is "no".    I'd hoped that maybe something had changed but I think that's where we got to when I looked at this before.
Thx anyway!
