Home Forums Products Stompboxes Updated Timefactor-still not getting patch names plus a bug? Reply To: Updated Timefactor-still not getting patch names plus a bug?
#133210
    timothyhill:
    Also, I have had some difficulty getting FactorLib to comminucate with the pedal if I have MIDI CLK OUT enabled. That holds true for the Update Utility as well. If I disable MIDI CLK OUT, everything works as expected. While this is rather an inconvenience, FactorLib is still a beta version.
    This probably only applies to Windows. We believe it to be a fault in the Microsoft MIDI driver or the Windows MIDI subsystem (meaning, most likely beyond our control).
