Home › Forums › Products › Stompboxes › Midi control of MF from TF › Reply To: Midi control of MF from TF
April 21, 2011 at 5:51 pm
#133242
I understand this. If your tempos are programmed (mine are not–I actually tap them in as live tempos are rarely that exact), you could easily send via CC. But, if your tempos are not pre-programmed, you 1st have to "tap" the tempo into a device that will send midi CC.
I think we got off track with all the discussion of rack gear. My desire is simple:
1.) Send PCs to both Modfactor and Timefactor
2.) Sync the 2 to the same (tapped) tempo.
From all discussion so far, it sounds like only way to do this is as I described above, using midi merge box to capture PC from controller and clock from Timefactor to send both to Modfactor.
