Home Forums Products Stompboxes Midi control of MF from TF Reply To: Midi control of MF from TF
#133245
Badmelonfarmer, yeah, that's the problem. I was thinking there may be two ways to address it…
First idea, GCP MIDI Out (PC and CC) to TF MIDI In (receiving both PC and CC set to "tap"), TF MIDI Out (set to Thru) to MF MIDI In (all on same channel, receiving both PC and CC set to "tap"). That wouldn't involve any merge boxes, and although technically MIDI Clock isn't used, setting both pedals to use the same CC for "tap" should sync the tempos as long as the GCP is used to set them. What this won't do is reset the tempo when it's stored as part of a preset.
Second idea uses a merge box to take PC from the CGP and merge it with clock data from the TF.
