Reply To: Midi control of MF from TF
Home Forums Products Stompboxes Midi control of MF from TF Reply To: Midi control of MF from TF
#133268
badmelonfarmer
Here we go, this is how I think you want it…
http://farm6.static.flickr.com/5185/5641261489_e9c1da8fe8_z.jpg
it got a little more complicated when I drew it out as you need to split the MIDI from the GCP to allow the PC and CC to get to the TF (to set the TapTempo) then you only set the MIDI Clock out of the TF…. so you need to merge the feeds from the GCP and the TF to get the ALL MIDI (PC, CC and Clock) to the ModFactor…. it gets easier then as it is just THRUs all the way out of the ModFactor and other devices.
I am no MIDI expert, just what I have been learning so you might want to check it out….but I am pretty sure I am right….happy to be proven wrong and learn….but this is what I have picked up so far with my MID frustrations.
Cheers
Martin
