Home Forums Products Stompboxes Midi control of MF from TF Reply To: Midi control of MF from TF
#133280
badmelonfarmer:
The way to think of this is that the GCP will transmit PC and CC but NOT MIDI Clock.
So, you need to transmit CC from the GCP to a device that can:-
a) accept CC for TapTempo to set it's MIDI clock
b) AND transmit MIDI Clock
You then need to merge the signal from the GCP AND the Clock Source back together to transmit to your other devices….. after that everything becomes more simple.
Yeah, the TF should be perfect for that along with the merge box we've been discussing.
