Home Forums Products Stompboxes FactorLib 1.8 Reply To: FactorLib 1.8
#133344
sjoplin
    Billy, thanks for the quick reply.  That makes sense about erasing a number of banks, or overwriting them and maybe dealing with patch name issues.  It's the leap of faith that the computer file is good so you can always go back to loading them up one by one in the order you want them in.
    To that end, dumping from pedal to computer seemed to work great, patch names, settings, everything.
    I'm also assuming the pedal by default will load the preset into the active patch on the pedal no matter with the bank number setting is on the FactorLib file?  So you need to make sure the pedal is set to the target location before you load it in from FactorLib one at a time?
    thanks,
