Home › Forums › Products › Stompboxes › Pitchfactor FX Loop Issue › Reply To: Pitchfactor FX Loop Issue
May 11, 2011 at 7:51 pm
#133381
Thanks for your answer. When I leave the FX Loop active all the time and bypass the effect with the PF switches then the problem is not occuring.
I think that you are right with your assumption that the signal is still sent into the fx loop. I will contact Earforce, maybe they have a solution.
