Home › Forums › Products › Stompboxes › Pitchfactor FX Loop Issue › Reply To: Pitchfactor FX Loop Issue
May 12, 2011 at 6:54 am
#133387
Earforce says that the fx loop is completely bypassed if switched off. They told me that I should try to set the input of the Pitchfactor to guitar level as the amps loop has a relatively low level. This could lead to a massive level at the FX return and possibly be the reason for the strange effect.
I will try it out at my next rehearsal and tell you about the results.
