Home Forums Products Stompboxes Powering Space on PP2+ (international) Reply To: Powering Space on PP2+ (international)
#133471
badmelonfarmer
    Hey Matthew,
    this is the sort of thing I was thinking of following our discussion over at TGP..
    http://www.stayonline.com/detail.aspx?ID=6626
    you could use something like this to plug into the courtesy socket on the PP2+ if you can find a PSU that accepts the fig8 (C7) connector.
    would probably be better if it had a cable between the two connectors rather than a rigid all-in-one connector.
    cheers
    Martin
