Home Forums Products Stompboxes Ultimate P/T/MFactor control with Musicomlab MKIII Reply To: Ultimate P/T/MFactor control with Musicomlab MKIII
#133600
caveman
    It's seems you could also use MIDI clock to chain the pedals together for synchronized tempo, then just use a 3 way parallel cable for the expression pedal.. don't know if that would be easier or harder for you but it would pretty much eliminate the MIDI programming..  I do believe the people at eventide said it would be ok to run pedal controller inputs in parallel? (A question for eventide)?
