Home › Forums › Products › Stompboxes › Timefactor Looper shortening my loops › Reply To: Timefactor Looper shortening my loops
#133645
DGillespie
    Hi Stephen,
    I do hear that, thank you.  Can you tell me a little bit about your setup, just so I can try to reproduce the problem.  Are you using tempo on or off?  Are you using Midi?  Do you have the looper record length set before you record, or are you manually stopping the recording by hitting the play button (it sounds like the second from the video, but I need to check)?  Also, what is the speed set to?
    Thanks for your feedback, I assure you we're looking into this issue and will fix it asap.
    Thanks,
    Dan
