Home Forums Products Stompboxes jumpy pitch with exp pedal – do i need a linear pot? Reply To: jumpy pitch with exp pedal – do i need a linear pot?
#133834
DavidYates
    Normal
    0
    false
    false
    false
    EN-US
    X-NONE
    X-NONE
    MicrosoftInternetExplorer4
    The implementation of the expression pedal on the ‘Factors
    is a bit confusing and it took me a bit to understand how I was affecting the
    operation by the way I was trying to use it.
    I kept forgetting that the pedal ranges are set by heel/toe
    positions and moving pots… I would be tweaking a sound and not give the ‘Factor
    enough time to not have the range setting active….
    Also, you need to power up the ‘Factor with the pedal connected
    for a “calibration”. Don’t forget some pedals have a knob that sets their
    range. My EV-5 has to be set at “0” for it to have full range. (Again, more
    goofy ,non-standard nomenclature in audio gear…)
    However, I have never experienced any “jumpiness” or other
    problems AS LONG AS I have had a linear pot (or CV source).
    I recommend getting all this sorted with an EV-5 or other
    pedal that others have had good luck with first before you suspect a problem
    with your ‘Factor.
    It takes time but is worth the effort.
    Oh yeah, the Moog MP-201 is off-the-hook good. I have not ventured into any midi experiments yet, but it does great things with my 'Foogers. Yet to connect to my Voyager…
    David
