Home › Forums › Products › Stompboxes › TimeFactor Power Supply › Reply To: TimeFactor Power Supply
        November 23, 2011 at 8:48 pm
        #133996
You are correct, the Factor pedals need isolated power supplies.
The 1Spot works fine it you only use 1 Factor pedal… But add another pedal you get noise.
I ended up buying individual PSUs for each factor… Worked well as isolated PSUs are quite expensive
