Reply To: Eventide TDM Reverb IN PTHD10 Win7 x64
Home Forums Products Plug-Ins Eventide TDM Reverb IN PTHD10 Win7 x64 Reply To: Eventide TDM Reverb IN PTHD10 Win7 x64
#134559
neilhester
Im afraid this one is back !
Im usinf 10.2 and its happening again, im not sure what fixed it last time but its definitley happening again.
Ive also worked out now that If i insert another eventide anthology bundle plugin such as "Factory"
into an insert slot first and then insert an eventide Reverb below it ,
it works as expected,
I can then remove this "factory" plugin from the first slot and continue to use Reverb as expected.
Sometimes after inserting another plugin in front of the Reverb and then
removing it, instantiating a new instance of reverb does not require
these steps as long as you do not close or reopen the project.
The fault occurs every time i open a project from ProTools but does not always re occur until opening a different project.
I have attached a flash video to demonstrate the problem.
[View:http://dl.dropbox.com/u/7388077/Eventide Reverb Bug.zip:550:0]
