Home Forums Products Stompboxes PitchFactor – Key Toggling Over MIDI Reply To: PitchFactor – Key Toggling Over MIDI
#134773
brock:
Is this the same "stringrazor" from the Cakewalk forums?
Yep.
Quote:
Quote:
Unfortunately, I believe only one such key modification can be programmed for the pedal as it's a global setting not per patch.
The "normal" FCB-1010 method that I use to switch keys & scale at the same time is to send the two static MIDI CC values without a program change.  One footswitch may produce A Dorian; the next kicks out E (natural) minor, and so on.  These are all in addition to the "saved" key / scale that pops up with an isolated program change message.  This works in either the Diatonic or Quadravox modes in exactly the same way.
Using the default PitchFactor CC Numbers as an example, CC #38 is mapped to Depth/Key:
C = CC Value 0-5
C# = CC Value 6-18
D = CC Value 19-28
D# = CC Value 29-40
E = CC Value 41-51
F = CC Value 52-64
F# = CC Value 65-74
G = CC Value 75-86
G# = CC Value 87-97
A = CC Value 98-108
A# = CC Value 109-120
B = CC Value 121-127
You can program in any CC Value within that narrow range per-key.  There are some advantages in some algorithms/parameters to using the highest CC value found in a given range.  In most cases, it doesn't matter.  Now, for the Speed / Scale parameter (defaulting to CC #39):
MAJ = CC Value 0-6
min = CC Value 7-15
DOR = CC Value 16-26
PHRG = CC Value 27-36
LYD = CC Value 37-47
MLYD = CC Value 48-57
LOC = CC Value 58-68
Hmin = CC Value 69-78
Mmin = CC Value 79-89
Wton = CC Value 90-99
ENIG = CC Value 100-114
NPLT = CC Value 115-120
HUNG = CC Value 121-127
So, for an E minor, send CC#38 – CC Value 51, and CC#39 – CC Value 15, from the same footswitch.  For A Dorian, it would be CC#38 – CC Value 108, and CC#39 – CC Value 26 on another footswitch.  And so on (ten keys + scales per bank).  Any combination of key and scale available on the PitchFactor can be called up remotely with one press (and two CC messages received).
Quote:
Using the FCB, I'd planned to use the UNO chip toggle feature which I think would make the process of changing keys much simpler.  The UNO chip is so useful and cheap, I can't imagine using an FCB without it.
I really should cave in on that UnO chip; it's a no-brainer.  I have the stock FCB-1010 (and tons of custom presets backed up) doing most anything that I need, though.  One of the "toggle" situations that I use involves the standard Controller Toggle feature.  I can switch between two keys, or two scales, but not both at the same time (using a single footswitch).
The other thing that I do is to process the MIDI Note that a switch can send, and convert that (through an external event processor) to a CC value.  That way, I can use the footswitches to act one way when pressed, and another way when released.  But that was my workaround in place before considering the UnO upgrade.
Great stuff! I will keep your posts as a reference.
I bought the PitchFactor for 1 song when I was performing regularly in an Eagles tribute band and it more than paid for itself. I had to change between 2 different scales to get the notes I wanted for the guitar lines during the verses of Hotel Cal (NOT the solos which we covered with 2 guitar players). Playing it as double stops didn't allow the right feel. When I used a Johnson (Digitech) Millennium Amp, I had its "J12" pedal (which had by far, the best, most flexible control architecture I have ever found)  configured to toggle keys on the built-in harmonizer and it worked pretty well.  Any of the buttons or  of the 2 CC pedals on the J12 could be set to perform multiple simultaneous internal functions PLUS send MIDI to other devices.  I still miss that control system. When I retired that amp from live use, everything else I tried glitched badly live so I decided to spring for the PF. Even though I just used it for ONE song, it was THE signature tune of that trib band.
The PF unit has a rather cryptic interface so I never really got deep into it once I was able to program the pedal switch. I'd always wondered what I could do with MIDI but never did the dive.
I REALLY WISH SOMEONE WOULD WRITE A DECENT PF PATCH EDITOR!!!!
The FCB is an amazing device for the money. The UNO chip really makes it shine as does the Ripwerks editor (toss that horrible manual tho'!). I also did the phantom power mod as my original use was to control MIDI fx modules kept on the backline. I always hated AC power cords at the front of the stage but eventually I got used to them.
