Home Forums Products Stompboxes Top 10 Annoyances of Factor Pedals Reply To: Top 10 Annoyances of Factor Pedals
#134778
garbagetruckdriver
    Regarding the Power Supply issue…  You need to check out TheGigRig (www.thegigrig.com)
    As you may already know, the issue with these units is the start up current draw – it's particularly high since it has to run a diagnostic which temporarily flashes the entire LCD display – there's your culprit… operating current is much lower.
    I have all four eventide stomps, plus four Roland expression pedals mounted on a PT-2 with all the power supply mounted underneath.
    Just ONE GigRig Generator is needed, then a distributor (which is just a punchdown block to distribute the wiring), and each Eventide stomp needs an Even-Flo adaptor.  I have just one IEC cable coming out to my board, very tidy…
